Migrating from previous versions
| Command | Path |
| Update Plug-in Objects | Tools > Utilities |
The Update Plug-in Objects command converts a variety of legacy objects to the current format. This command works across all file layers, and as applicable, on objects that are freestanding, inserted in walls, in a placed symbol, or in a symbol definition. All applicable parameter values, and any attached records are also transferred during the conversion.
Saving a copy of the file prior to running the command is recommended, as the command cannot be undone.
To update plug-in objects:
Open a file containing legacy objects.
Select the command.
The Update Plug-in Objects dialog box opens.
Select the type of objects to convert to the new format.
All older version objects of the selected type are converted into the new format.
